JASTN70D
I think of all the applications you list there is only 1 that is a bottom limiter (I.E. size/weight) that would be finish mowing. It seems everything else you need to do is where the adage applies bigger is better. One other point is the % of time spent on the tractor will probably be mowing 70% ???. HST is great for mowing if there our any obstacles to mow around also smaller tractors tend to have smaller turning radius.(Except super steer) I guess if I had to do it I would look for the biggest tractor with the most fitting features that you could use for finish mowing. Hopefully that choice will be large enough for the other chores. If not you may have to consider 2 different units for the jobs. Tough decision. Good luck.!
