geneP
Platinum Member
- Joined
- Jun 28, 2000
- Messages
- 815
- Location
- Central Mississippi, USA
- Tractor
- Case-International 385, Kubota L5450 w/LA1150A loader
One of the original questions was "What's it's purpose?" on a John Deere tractor. I don't know for sure, but after reviewing all the definitions of an accumulator, I'm guessing (if it is indeed an accumulator) that it is to smooth out the hydraulics operation. This is an industrial tractor, so the pump GPM is probably higher than a similar ordinary tractor. Let's assume that it has an open hydraulic system, so there is minimum pressure in the supply line from the pump while no functions are open. If you were using a FEL, for example, and had a relatively heavy load in the bucket and wanted to raise the load. When the "up" valve was opened the supply line pressure almost instantly increases to a point high enough to move the cylinders. My thought is that the accumulator in this case is used like a standpipe, and cushions the initial surge of pressure to minimize the shock at the bucket. Does this sound reasonable?
