texasjohn
Super Member
Yep, total empty weight plus payload varies with length, etc.
I found this site that gives a good table for their 16', 18', and 20' dual tandem dump trailer.
I do note that their actuator is only 10 tons... not the 18 that you recommend. There are a couple of trailers that I have found that have 20 ton lift capacity (at least that is what they say).
So, I think that if I go with a dump trailer I'm now biased toward the following:
removable sides
18+ ton rated cylinder dump capacity
two cylinders (for both capacity and stability when dumping)
spread dump gate as well as barn doors
12k axles for total 24K capacity (not 10K ea. which is more common)
still fretting over 16' / 20' length. Price/availability may be the determiner.
Good advice, all... thanks!
removable sides
