Rich1954
Hello.
I acquired an Iseki tractor when I bought a new house. I'm not sure what model it is and I don't know much about it besides starting it up and using it to cut grass with the attached 3-point hitch mower and using the frontend loader to move a shipment of wood pellets to the storage shed. It's been running great. I will need some help identifying what it is later and will post some pictures of it then(if I'm able to), but if it helps with the answer to my below question all I know about it right now is from the ID plate I found in the right footwell on the transmission tunnel---TL12EF-01283. I know it's 4 wheel drive and has an Isuzu 4 cylinder diesel engine.
I have a small leak, maybe 7 or 8 drips while cutting grass in about an hour, from a hydraulic coupler going to the frontend loader. I plan on changing all hydraulic lines/couplers to the frontend loader this winter. The drips are yellow in color. The dipstick for the hydraulic reservoir shows the yellow color too. I need to add some fluid. What type of hydraulic fluid is yellow(I thought all hydraulic fluid was red in color) and who makes it---can you suggest a brand? Can I mix red hydraulic fluid with yellow?
