J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,928
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
If you want an analogy, consider a 3000 psi pressure washer with the bullet stream nozzle on the end, engine running full power. If say your kid was playing around and put the nozzle against your leg and pulled the trigger, It would probably inject a pint of water under your skin and muscle. and would cut, tear or split your leg. That would be bad enough, but do something similar with hydraulic fluid, that would be really bad. Now they have to get all the hyd fluid out, plus any shin/muscle that was injected. Nasty bad as in that picture. In that picture, you can see about where the fluid was injected. That 3000 or greater psi was just there and burst at the weakest point.
