RonMar
Elite Member
My problem is the wrong fluid was used in the machine and its foaming, previous owner used ATF instead of hydraulic fliud and every once in a while itll spit pink foamy pepto bismol out that spout.
ATF IS hydraulic fluid... It might be a little thin for this application though. You might be leaking air into the suction side piping that is helping create the foam. On mine, there was a pipe union right where the supply line to the pump comes out of the reservoir. That union was loose and would allow air to be injested into the system when running causing foam and jerking operation. The union had only the barest hint of fluid around it though. Pressurizing the system at the filler with compressed air will show it as a leak plain enough.
Once that union got snugged down, no more foam...
