MarkGrabb
Hello All - For the first time after owning the tractor for 7 years... I bought an implement that required hydraulic hookup. I planned to use the hydraulic connections for the two hydraulic lines from the implement at the front for the curl of the front loader. I took off the top quick connect by mistake (which happened to be the "up" hydraulic for the up and down of the loader.) I took off the bottom two hydraulic lines to connect the hydraulics from the implement... but I couldn't get the top quick connector to connect back in. I relived the pressure from the loader by jiggling the joystick with the key off... and I removed the pressure from the connector by wrapping it in a rag and tapping it.... but it still won't connect. My curl works on the front loader (I have both lines securely connected). However, neither my up nor down works on the front loader. I have the down hydraulic securely connected, but it still doesn't work. The up hydraulic won't connect.... so I am less surprised that the up doesn't work. I added some hydraulic fluid. When I curl the front loader... the bucket stays suspended in the air.. so I assuming it is holding pressure.
1) Do I have to have both the up and down hydraulic lines connected for up and down to work? 2) Could I have gotten air in the system... and if so.. how would I bleed it? I am used to working on cars... but I am at a loss when it comes to working on tractors. Any clues you can provide will be greatly appreciated, Or if there is something I should try... I can do that and report back. I have twenty acres of straw that was combined by a friend for the seeds... but now I need to cut the remainder and get it baled before if goes bad... so I really appreciate any insights.
