let's try this, from the JD tech site, here is a solution
that may help, in the end it refers to 3ph also:
HYDRAULIC LOCK-OUT VALVE ON SCV DOES NOT WORK WITH 45 LOADER X400 AND X500 SERIES LAWN AND GARDEN TRACTORS
Complaint or Symptom:
Hydraulic Lock-Out Valve (AM131526) is installed on SCV coupler housing but:
- Mower deck (or other attachment) raises, lowers or moves when 45 front loader is operated.
-Delayed functions noticed in attachments when used with loader.
-Valve does not seem to stop hydraulic flow to mid-cylinder like previous 425-455 models.
Situation:
Early Operators Manuals did not have complete information on how to use valve.
Wrong procedure used when closing hydraulic lock-out valve.
Solution:
1 Fully raise mower deck lift arms and set mower cut knob to highest setting.
2 Lower deck lift arms with SCV lever to be sure it is against depth stop.
3 Close hydraulic lock-out valve.
Additional Information:
- Rockshaft must first be raised then lowered to depth stop before closing lock-out valve. Valve on X-Series is installed so it shuts off oil on opposite side of lift cylinder.
- If a 3-point hitch is installed, it must be locked up manually using the depth control adjustment at rear of the tractor.
- Instructions for installing the lockout valve are included in the appropriate attachment Operators Manual.
- Operators Manuals will be changed at next revision.
