dkhntr04
Hi everyone,
I'm looking for some outside input and proofreading on my calculations for my snowblower project. I am looking to convert my Farm King SB80 80" 540 RPM 3-point blower to SSQA loader mount with hydraulic drive. I am looking to build the hydraulic power pack myself using the mid PTO on my 3720 to power it. Please take a look at my calculations and component selection and let me know if you see anything that doesn't look like it will work. There is a lot more to the project besides these calculations, but please stick to just these for now.The one big question I have is if there will be any issues regarding motor/pump efficiency.
The Parts:
Pump: Surplus Center - 1.74 cu in BORG WARNER S20S15DJ11L HYD PUMP
1.74 CI, 3000 PSI Cont. 3000 RPM Cont.
Motor: Surplus Center - 7.1 cu in PARKER 110A-071-AS-0 HYD MOTOR NP
7.1 CI, 3000 PSI Cont. 3500 PSI Max, 3000 RPM Cont.
The Plan:
Drive the pump off the 2100 rpm mid-PTO on the 3720 either direct mount or by drive shaft depending on what fits. Run the engine at 2723 RPM to produce a 2200 RPM PTO speed. 2200 x 1.74 = 3828 CI/Min (/231 = 15.8 GPM)
Run the blower with the 7.1 CI motor. 3828 CI/Min pump flow / 7.1 CI motor = 539.15 RPM for the blower.
Horsepower: Relief valve set at 3000 PSI. 3000 x 15.8 gpm x .0007= 33 hp required. Surplus Center's calculator says 32 hp. 3720 puts out 35 PTO HP, so I should be good on power.
Torque: The motor is rated for 2915 In/Lbs of torque continuous, 3401 In/Lbs intermittant. The 3720's engine puts out 84.3 Ft/Lbs, or 1011 In/Lbs. 2600 engine RPM / 540 PTO RPM = 4.81. 4.81 x 1011 In/Lbs = 4867.7 In/Lbs of torque at the PTO assuming an impossible 100% efficiency. Assuming 75% efficiency would be 3650 In/Lbs. In the ball park. I ran this blower with a 23hp PTO tractor last year, and it had enough torque to spin a full impeller/blower. I am not concerned with torque, should I be?
Let me know what you think. Thanks:thumbsup:
The Parts:
The Plan:
