I guess my terminology has been wrong - I have always understood that "one remote" meant that you had one remote valve with two connectors. Each connector set (remote) gives a "push" and a "pull" function (more like extend and retract) to the cylinder it's connected to. So I'm installing three remotes, giving me six connectors.
Buying the factory parts to add the VALVES after your initial tractor purchase will be $$$$. Everything I have ever heard says that buying the tractor with them already installed, either at the factory, assembly point, or dealer, is way less expensive. All the factory Kubota parts for 3 "float" valves, hoses, and rear quick connectors for my L4330 were $1800. I bought the top and tilt cylinders from Brian like everybody else on here.
