MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,456
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I'm surprised somebody hasn't also mentioned that you can add an adjustable needle valve to one side of the hydraulic circuit also. The needle valve will give you complete control of flow for any sized cylinder, but is more expensive than the simple orifice. I've also been advised that you should not install an orifice just before a right angle connector. The high pressure jet can actually cut through the fitting. This is hearsay, but comes from Mark Carter of CCM. Frankly, if you are not in a constant flow situation, I think the chance of this being an issue is nil.
Jim, it was my own personal experience that has turned me off on the use of needle valves to control the flow for Top & Tilt cylinders. When I first put the "TnT" on my 32hp tractor, I used needle valves to control the flow. Did they work, yes. did they work good, NO. To get the needle set the best that I could adjust it, I had to have the needle valve closed all the way and then open it they smallest amount possible. That is actually harder to do than it sounds. Anyway, they did work, but even with the needle valves the hydraulics moved a bit faster than I liked, but they were manageable and I used them like that for years.
When I put the restrictors in and got rid of the needle valves, WOW, this is sooooooo much better. For me anyway.
