/ I have a Massey Ferguson 1533 year 2006 It's is overheating to a the max and past I replaced the Thermostat flush the sytem with water What else
#1
I have a Massey Ferguson 1533 year 2006 It's is overheating to a the max and past I replaced the Thermostat flush the system with water. Still over heats less than 15 minutes what else could it be ? Oil is fine no sign of water in the oil no leaks. any Idea's what I should do ? Thanks Frank
Upon further inspection the culprit was the overflow outlet pipe by the radiator cap had a hole when hot coolant would leak out and run low since i was in the field I did not see any wet spots looks like the only fix is a new radiator the pipe is plastic $800 plus for a new radiator AUGHGGGGGGGG. Its suppose to be a closed pressurized system.
Thanks for all the responses
