I hope my story will save someone one day
   / I hope my story will save someone one day #21
Wow, glad to hear that you made it through this experience, I appreciate you taking the time to post it, to serve as a reminder to all of us how fast things can go wrong, even when we think we have it all under control.
Get well soon.
   / I hope my story will save someone one day #22
Get well soon! If it's any consolation the same thing has happened to me with a big pine. I was lucker than you though. The darn thing just slid straight down and then fell. It just scared the heck out of me. The only thing that I can figure was the angle of the cut was a little more than I normally do and there was probably some downward angle on the bottom of the notch-out. I'm a whole lot more careful now!
Good luck with your recovery!
   / I hope my story will save someone one day #23
burnetma said:
DDT,
The first was killed by a falling dead limb that seperated from the tree while falling. The second killed one of his children when the tree fell the "wrong way" (I will not get into why anybody would cut down a tree with two children under 15 years old with him).
Mornin DDT,
burnetma brings up a very good point about dead limbs ! Im always worried about that potential problem. I always try to evaluate the lean of the tree if any and try to base how Im going to fell the tree using that info. Afer I have notched the tree in that direction I have some 1" line thats about 100 ft long and tie off from the tree to my FEL. Of course this only works when Im dropping trees from the hedgrows into the open field. I put some tension on the line and make the back cut, always having an easy escape route. I try and get rid of any small undergrowth in the immediate vicinity.
I also have a hard hat, that truthfully Im not always concientious in wearing:confused: :( After reading this thread, I better start using it all the time ! In reality I dont know how much the hard hat would help if a 3" branch dropped on my head from 40 ft, but any help is better than none !
In any event, Im really glad to be able to have this conversation with you, and hope you get well real soon ! :)
   / I hope my story will save someone one day #24
Thank you for posting your story hopefully it will allow someone that has not had very much experience felling trees to be aware of how dangerous it can be. I grew up with my father cutting trees on his farm and as I got older and got my own farm cutting trees for firewood. My father taught me that when i cut down a tree to do what you did make a notch and then make the hinge. I cut the hinge to where it is short of the notch then I set my saw down and push the tree over. One of the things he made sure that I learned was to have a clear path to run and make sure which way it was before I ever started cutting. One day I cut a tree as I always have but I cut my hinge a bit too deep. I set the saw down and pushed the tree to push it over. The hinge broke and the tree started slideing down the notch and falling. As soon as the hinge broke I took off running I never stopped to think or see where the tree was going or nothing I just ran when I heard the tree hit the ground I stopped luckily for me it fell the other direction from me. I am glad that although your injuries are severe they are no longer life threatening and that they sound like something that will heal.
   / I hope my story will save someone one day #25
DDT
Thanks for sharing your experience with the tree, the saw, and the angel. I am glad the outcome is so positive--although certainly painful. Similar to you, I have cut trees for firewood and lumber for much of my life. My most memorable experience with the tree, the saw, and the angel occurred eight years ago when I was 45 years old. It involved a small oak tree (~30’ tall, 8” diameter) and a nylon rope come-along (lots of stored energy when tight) and resulted in a broken foot, fractured pelvis, cracked ribs and an anterior compression fracture of the L2 vertebra. No surgery was required, but recovery was gradual and extended over several years. During the early stages of recovery, I doubted my choice to cut trees and thought that it may be sensible for me to put away the saw and pursue “less risky” activities such as knitting, reading, and breathing. Later as my strength and confidence returned, I chose to again lift the saw and cut trees albeit with a greater awareness of risk and a greater focus on safety. In retrospect, the “experience” was indeed positive. Be patient, and you (and your angel) will again pursue your passion. Best wishes.
LogChain
   / I hope my story will save someone one day #26
DDT,
Thank you for sharing the story of your unfortunate accident. I hope that you will be feeling better soon. Although I have felled a few trees in my time, I probably have not cut near as many as most. Because of this, I never fell trees alone, and when possible I use guide rope(s) that I secure to the upper part of the tree. I find it is easier/safer to cut out a wedge, then have someone pull/load the tree in the direction of the fall as I cut the back of the tree, instead of trying to cut and push the tree over by myself.
Hope you have a speedy recovery.
Jim
   / I hope my story will save someone one day #27
DDT,
Whishing you a speedy recovery from theat scary incident........Can happen to anyone ,,, anytime... Life is precious.
   / I hope my story will save someone one day #29
Life is short and precious.
It can change in an instant of time.
I'd say, share your good fortune with others. Be gratefull.
-Mike Z. :)
   / I hope my story will save someone one day #30
So far, 28 of 28 replies to DDT's post have expressed sympathy but offered no insight at all into how this accident could have been prevented. If this is the safety forum I think we should refocus the discussion so we can help each other learn something rather than see this as just an extended "get well card".
Why did this accident happen? What preparation/equipment/technique would have prevented it? Was it predictable with an opportunity to learn from a mistake or does this just fit into the category of "Sh-t happens"?
Black Steel Diamond Plate (A55758)
Black Steel...
(3) 66" PADFOOT SHELLS (A52706)
(3) 66" PADFOOT...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2012 C&M TRAILER 14 T/A ENCLOSED CARGO TRAILER (A55745)
2012 C&M TRAILER...
2001 Ford F150 (A50121)
2001 Ford F150...
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
