cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,737
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
Pete,
Yes you can just use the clay for your base. There's really no reason to have the drain in the indoor.
Everyone worries about the top of the arena but it's your base that is important, esp. with reining. You've got to have a smooth hard base for them to slide on. If you are seriously into reining and maintaining your hard work on your arenas invest in one of the arena groomers. You won't do squat with a chainlink fence. Plus they will allow to control the depth so that you don't tear up your base.
If the excavator is coming back you need to get it dug out 4" below where you want your grade for your arena to be and it has to be absolutely perfectly level. That will give you a good arena for years to come with minimal maintenance.
As far as your outdoor arena it depends on your rainfall. Back home in Idaho we never worried about drainage as we don't get hardly any rain. In the midwest it's a constant battle with rain. My arenas are all tiled with the slope of the ground. You have to get the water drained from the middle as well as the outside. For the outdoor I would crown the middle and slope it sideways very gently. As long as you you compact the base very solid then you shouldn't have a problem. The tile will drain what leaches through the ground and the slope will take away the majority of the water.
I would rent a compactor if you want to do it right. YOu can get a heavy roller but you will have to compact it, wet it down, compact, wet it down, etc. I would use the same sand in the inside as well as the outside.
It definitely would be great to mix the rubber with the sand but most arenas are sand, even the big boys don't use rubber much.
