JerryK
Elite Member
- Joined
- Feb 21, 2004
- Messages
- 3,266
- Location
- Vanderbilt, Michigan, USeh?
- Tractor
- Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Don't know about a vapor barrier. A pole barn has a lot of moisture in the winter with vehicles/tractors/people tracking in and out/etc. There is probably not many pole buildings that don't leak a little water thru their lifetime. The moisture has to go somewhere, so I would not try to make it too tight.. In my barn, when the roof has a foot of snow on it, the moisture forms as frost on the bottom side of the sheetmetal roof, then when the snow slides off, the frost melts and rains down a little onto the top of the foam panels. The only way you can stop that is to insulate directly onto the roof sheetmetal bottom. But you would still have to have a false ceiling insulated to keep the heat closer to the floor. The under the roof insulation would make it hard to locate leaks in the metal roof, if you ever got any. You can spray foam under the roof, but that isn't cheap either. You can get frost on the bare walls, too. But it does not take much of a barrier to keep that from happening. The foam or even a sheet of chipboard would probably stop that.
