CHF4, why would you want insurance? This is a question you need to address before you buy. Not all cover the same.
On the tractor you described: working tractor with a door open..catch something and there goes a thousand of so dollars. Or you have a side mount cutter on it and a pin comes out and it swings into a fender busting it and there goes a thousand dollars (this we mine) , or you make a bad turn and roll in a ditch not good for the cab or operator amount could be major and or course the two and four legged pest. There there is liability coverage just in case you have any kind of accident damaging someones property.
You will enjoy a cab tractor most of the time but pretty weather and limbs will make you miss it. Cab of course helps protect from the weather, gives you cleaner environment from dust and sprayer mist and the flying insects such as wasp and well just bugs. Again, congratulations.
Thank you. Good info & things to think about for sure. I have a smaller/older 40hp open station that I can enjoy pretty weather with or low profile stuff.
Hopefully the sunroof (visio roof) will help with limbs.. but I’m sure there will be some learning curves..hopefully none too expensive.
I am looking forward to not breathing the pasture pro selective weed killer for the horse pastures when needing to spray. Also with our bottom flooding some this past yr a couple times it sure will be nice to not eat a few pounds of dirt. I lucked out this last year and was able to mow them while demo’ing a couple cab tractors. It was a dust storm while mowing. Had to scrub down and pressure wash the tractors it was so bad.
