I think the way you are approaching this conversation is not helpful. When you state the Branson is "underperforming, not close to the norm" and so on, which is your opinion - and said in a way that begs for a defensive response. Apparently max loader lift height is really, really important for the kind of work you do. If so, you ought to focus on that. But I have sold thousands of tractors and the average CUT tractor carries around a bucket of material at or below hood height and only goes higher to dump over a fence, or a dump trailer rail, etc. Seldom is max height an issue. Now if you stack bales high in a barn, load a 10-wheeler or some other tasks, the height can be absolutely critical. A few inches is a go or no go. I understand that, but this is not the most important column on the spreadsheet when most folks buy a tractor.
I'm only comparing specs, and talking about facts. Since the machine you're supporting, and sell, has lower specs I can see how you'd find that less than helpful. I never said it was the most important factor, just that it is a factor to consider and then the defense of factual numbers kicked in.
You can find a spec on about any tractor to beat up. For example, I can probably find one of these heavy lifters that uses a pump that isn't proportionally larger in relationship to the larger cylinders. This will be a slower loader. That to me is a bigger issue. I really dislike a slow loader. So then we can make a huge deal out of why I wouldn't even think of buying an underperforming brand x tractor because I don't have all day to wait for the loader to do it's job because one loader takes 6 seconds and another 8 seconds, 33% slower! But I would not then declare that tractor as substandard and under performing. Pretty much every model will have some areas where they top the chart, and some areas where they do not. The key is to figure out what is important for the operator and/or the tasks at hand. But at the end of the day, the average user has just wasted 1 minute with the slower loader! Why would they care? Most wouldn't, but just like you care so much about lift height, some people focus on some other issue. So if this is important to you, good. But man, let's keep it in perspective.
If you'd like to discuss pump flow and cycle times, they would be completely valid numbers to compare, but I haven't seen you do that. Why not post some of those facts as an offset to the lower lift height and lower lift capacity that's been pointed out? Now THAT would be useful coming from a dealer, not simply defending a low lift height and a low lift capacity figure that isn't in question. If you said "well, it might not have the lift capacity, but let's look at how cycle times compare" or something similar, nobody would take issue with it.
I mention to you that even at 60 HP, the Kubota only lifts 75 lbs more at max height, and then you make a huge deal about how the Kubota, as it passes through the lift arc would lift hundreds of lbs more at the same point indicated as the max lift height for the Branson. Why confuse things with that concept that probably is not true? That is silly math, if math at all. I suspect at 104" the Kubota would still be at or near max at 2275 lbs.
Again, the horsepower of the machine is irrelevant, especially when it's already been noted that the 48hp version of the same tractor has the same loader specs.
If you think my statements about lift capacity changing with lift height are wrong, you may want to do some additional research. A loader that lifts 2,000lbs to 100" will be able to lift a fair amount more to only 90". The exact amount will vary based upon geometry, cylinders and hydraulic pressure, but it will be enough to notice a difference. Some brands list lift capacity at 59" as well as at max height, and it's frequently many hundreds of pounds more. It would be great if all brands listed that spec as it would remove all doubt as to the relative strength of any loader.
My point was that the Branson is in the ballpark with the other players. Yes less then average for the group you listed, but certainly not embarrassingly so, and more than adequate for 95% of what most folks do with this size tractor.
It's probably enough for what many people do, but it's still near the absolute bottom of all loaders in that size machine...lift height, lift capacity, even the rollback and dump angles you mentioned are all at the bottom of the class. If someone is fine with their machine having bottom of the class performance in their FEL, more power to them (they might need it).
I'm not sure why you are going after Branson with such vigor.
Again, I'm not "going after" anything, I'm simply talking about the specs of the machine this thread is about. The facts are what they are, and if they aren't flattering, that's got nothing to do with me. There's an old saying: "Don't shoot the messenger." You may have missed that I was even more critical of the lift height limitations of the LS that I owned previously (and said as much in this thread). It was only 96" to max lift height (2,500lbs) and that seems to be the worst around for that size machine, but that's just the way it is.
Moving on would be awesome!
