This has been a pretty good old tractor, it is only used about 12 hrs / yr.
The last time it was used, it ran good, it was shut off with the jd shut off cable and left pulled out. It sat for 2 months and will not start. I changed the filters, it has fuel to the pump, the return line from the pump to tank is flowing. I removed one of the lines at the pump, pump not pumping. By leaving the shut off cable pulled out, could something get stuck inside the pump?
Need help, thanks nick
