LD1
Epic Contributor
You need some R1's if you plan on doing that very often:thumbsup:
Figured you all might enjoy watching some of this.
I thought you had the right idea at first, back dragging material into the soft areas causing you trouble. It just seemed you weren't dragging back far enough to fully fill in where your rears were digging.
Looks to me like you just needed a little momentum to get up that hill. Trying to creep thru mud and climbing a muddy hill with R4 tires just don't work. Raising the bush hog off the ground would have helped a lot too.
better off to cut the top of the bank with the loader and dump it off to the side to make a ramp, that way it'll be somewhat solid.
This looks like snake country. This means there could be snakes in your tractor. If you have access to a large drive in freezer with a door big enough for your tractor you can bring it inside and keep it at 0* F. for 48 hours. Otherwise, I am afraid you will have no choice but to burn it.
