greg_g
Super Member
- Joined
- Dec 18, 2003
- Messages
- 6,086
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
I've just embarked on the spacer road recently, and right now all I feel is insulted. John Deere told me that I bought the wrong tool for my property, that it's my fault that I own an unstable tractor. Jeez, this is western Kentucky - there ain't nothin' flat here. Maybe John Deere just shouldn't sell CUTs here at all. Anyway, I maintain 30 acres of diagonal with my 3720. Fourth tractor I've owned here, and I didn't have any "tippy issues" with the first three. So I first upgraded the 3720 from skinny R1s to wide R4s. That turned out to be a waste of time, because the max R1 rear track of 68.4" was reduced to an R4 max of 59.7 inches. So I added nearly half a ton of liquid ballast to all four R4s. Helped some, but not enough. So I'm moving on to spacers.
I agree with the poster that said there'd be too much stress if you put them on a backhoe-equipped 3x20 series, but feel they're perfectly legit otherwise. Unfortunately, John Deere doesn't. I was told flat out "if you put something on there that you didn't buy from Deere, all bets are off". Once I install spacers, they'll refuse to honor the warranty for any rear drive related issues.
I'm no mechanical engineer, but I'm pretty sure they didn't think through this excuse; the service manager said "it puts too much weight on the (axle) bearing". If I had a backhoe, I'd have bought that. But I don't, and I won't. Besides, they were more than willing to sell me ballasted R1s set out to 68.4 inches. Deere also sells a fender extension to accommodate for that width. My spacer plan will result in R4s set out to 66.1 inches, well within the "authorized" max for R1s. That argument was lost on them.
Spacers simply move the wheels a little farther away from the hubs, there is no extension of the axle involved. Backhoe equipped 3x20s aside, the only weight the bearings support - and by extension the rear axle housings - is that of the tractor itself. Adding a spacer between the hub and the wheel does not increase the net tractor weight. And weight beyond the hub - spacer/wheel/tire/ballast - is supported by the ground. Unless the tires comes off the ground, there is NO additional "weight on the bearing". And the whole idea behind the spacers is to PREVENT the tire from coming off the ground in the first place.
Anyway - I'm going ahead with the 4" (per side) spacer installation, ordered them from the machinist today. I'll also add the "JD-authorized" fender extensions as well. Will update everyone as the situation progresses, but in the mean time I also invite any discussion or comments.
//greg//
//greg//
