TractorTYMe
Veteran Member
Plus the Branson has a very very reliable mechanical injected low tech license made Cummins A2300T engine made by Kukje.
Is the Massey in stock so you can at least climb around on it and test it out?
Good luck and post pics when you get it home.
We like tractor pics.
Avoiding the obvious discussions I’ve found myself in a position to choose between these two tractors. The cost per month would be almost identical due to better financing rates being available on the Deere.
I plan on keeping the tractor for 10-20 years minimum.
The Branson has a separate lifetime extended warranty on engine/power train.(It’s written like a home warranty sort of)
The main tasks I’ll be doing with the tractor will be:
- Mowing with a 6 foot finish mower
- lifting pecan super sacks (1500-2500 lbs) onto a car hauler
- operating a lane shark type loader mounted brushcutter
- general landscaping work
Both tractors will run the finish mower perfectly
Both tractors weigh almost the same.
Both have similar hydraulic implement pump flow for the lane shark operation.
There are two key area of concern I have:
-Loader capacity. The 440R loader has 6” more lift height than the Branson BL200 liader(110” vs 104”) however the Branson has more lift capacity at the pins at full height 2701 lbs vs 2539 lbs. Both have a 2500 psi relief valve.
Is the Branson optimistic with their loader rating? Is the John Deere conservative? Are they comparable in the real world capacity or is the difference as much as indicated on paper?
- Is there any notable features on the John Deere or Branson that will make any of my tasks noticeably easier or less stressful on one tractor vs another.
I looked at your list and you may be best served by a couple of different machines. Lifting 2500 pounds with a compact tractor is going to be a tall order. Depending on how high you need to lift it, the loader may or may not be able to do so, but if it does, the machine will need all of the counterweight you can put on it and it will not like it very much. Remember that the lift capacity is at the pin height and your load will be sticking out further than that, exerting a cantilever effect and reducing lift capacity. I would be looking at a full sized utility tractor or a skid loader to lift that much weight. I have used a New Holland Boomer 50, which is a competitor to these tractors with similar specifications, and it is a handy tractor but it absolutely knows it has picked up a 4x6 round bale off of a car hauler trailer. Those bales weighed about 1000-1200 pounds, and I would not try to pick up more with it. And that tractor also has loaded tires and a backhoe hanging off of the back, so it is pretty well counterweighted. I would think if you can absolutely keep the pecan sacks to no more than 1500 pounds and don't have to move them very far you may be okay though.
I would also look at a smaller unit for the mowing and landscaping. You don't need anywhere near a 50 HP tractor to run a 6' finish mower and you also don't want that weight on your lawn if you can help it. It will also be a pretty long and not very maneuverable machine not well suited for mowing anything except a fairly wide open area. I know, I used to mow my lawn with a tractor the size of a Deere 3 series and a 6' rear finish mower and had a massive improvement in mowing speed and enjoyment when I traded that for a zero turn mower. A zero turn won't be useful for landscaping, but something like a subcompact (1 series) or a smaller compact (2 series) with a belly mower would be better suited for lawn mowing and landscaping.
I drove the 1840M and 2850M when I was shopping, both great machines. The $10k price difference between the 2850M and the DK4510 nudged me toward the Kioti. It was a hard decision though.Also for those that are curious, here are the features that made me choose The MF 2850M over the Branson 20 series CH.
In no particular order:
- Air ride seat
- Easier ingress/egress of the cab
- Seat that adjusts further forward
- speedometer
- adjustable transmission(response and speed limiting, both via knobs)
- Easier to operate cruise control (push to engage instead of push and hold)
- removable clean out screens on radiator and condenser
- more advertised breakout force on the loader
- wheels accept iron wheel weights
