Charging circuit is not working. You're running off your battery until it's dead. You need around 14.25- 14.5 volts at the battery when the tractor is running - what is it reading?
Yes, the voltage at the battery is around 12.5. I have tested the alternator per the shop manual and it appears to be working as well. The battery charges normally. I have replaced the voltage regulator. The alternator on this unit is a 20A alternator. I have done quite a few of the tests and have not located a problem. Why does the alternator light not come on? Thanks for the response.
