Just finished one side on this job, taking a lunch break. The job is not too bad, but If one is not a moderate/advanced DIYer, I would not recommend it. I ended up *not* having the tapered bearings (which is a more difficult job). A hydraulic press is required to do the job properly -- would not touch it without it.. Harbor Freight had their middle one on sale today and, with the 20% coupon, came out to be a little bit more than $100. The thing that makes the job more difficult is that the instruction sheet that comes with the seal specifies a .060" rise above the housing. I have depth gauges, so I was able to measure it precisely. I assumed that JD must be having problems with these seals because 1) they have been updated and 2) they have a precise depth for the seal. Now, of course, the reason for the precise depth is that the new seal also has a "flange" that "rides" on the hub facing the tire (in addition to the "typical" sealing surface) -- hence the precise depth measurement. During assembly, when I put the outer bearing in and seated it, the hub had a little more resistance than I was comfortable with when turning to check it, but I assumed that this was because of the additional mating surface for sealing. However, by the time that I had installed the inner bearing, the turning tension was less.
For those that are uncomfortable doing this job, the removal of the hub from the axle is *easy* and, if done by an owner that is not putting the seal in, this would enable you to take the hubs to any repair/machine shop and have the seals installed without taking the tractor.
More later if I have any additional observations . . .
Richard Easley
Waco, Texas
