I think your dealer needs to wake up, this has been out and avail to him for quite a while........
Solution Number: 53287
Doc ID: WX53287
Solution Summary: Shear Bolt Fails Easily on 413/513 and LX4/LX5 Rotary Cutters
Publication Date: Jul 12 2002
Complaint or Symptom:
Shear bolt fails easily.
Problem or Situation:
Tractor PTO engages too aggressively, PTO cannot be modulated, or material being cut is too dense and heavy. This may too much stress to be placed on shear bolt causing failure. The 19M7329 repair bolt may not be strong enough when any of these conditions exist.
Solution:
Install 19M7479 Grade 8.8 bolt that has a longer shank. If application is still too heavy, a 19M8081 Grade 10.9 may be tried but care should be taken. Increasing shear strength of bolt may result in other damage to the driveline if due care is not practiced. The best solution is to install a clutch protected driveline.
413, 513, LX4, LX5
DRIVELINE, MISC, PERFORM, BROKEN, FAIL, BOLT, COMPONENT
