I have a 1997 JD 5400. Initially I started losing power, got hard to start and eventually would no longer start. Filter and tank were full of gunk and water. Changed filter, cleaned primer on top, blew line to tank, drain and flushed tank, changed all fuel line, return line and vent with line. Solenoid valve at injector pump is working fine. I got everything primed back up. Tractor will start fine and run fine now except for when I throttle down to idle it will die. Starts right back up. do I have a problem with injector pump or injectors. there was a lot of crud build up in those old lines. I’ve had the tractor for 5 years never had a problem other than the normal maintenance stuff like changing fuel filter.
