I'm moving on to the fuel shut-off solenoid.
I found a test that was posted on-line that I'll try...
Don't start the tractor, but try turning the key to the ON position and then turn on the headlights and see if the fuse blows...
If the fuse doesn't blow
Check the solenoid
Fuel Solenoid Gound Test
1. Key off
2. separate connector at solenoid
Check continuity between harness side of connector and ground at battery negative post
Must be 12vdc...if so replace solenoid otherwise poor ground...clean and repeat
Fuel Shutoff Solenoid Holdin Test
1. Turn key on
2. push solenoid in and release...It MUST STAY IN
If it doesn't proceed...
Fuel Shutoff Solenoid Voltage Test
1. Turn Key on
2. Check for voltage at connector to solenoid...should be at least 9 volts
If not, reverify your ground and if that's okay...REPLACE SOLENOID
Check the solenoid
1. Key off
1. Turn key on
1. Turn Key on
