cannyscot
jd2320 has been idle for a month or so. Starts good, run’s smoothly, but when I try to engage the transmission range lever into either high or low range the engine stalls and quits, Any suggestions as to what might be wrong and/or corrective measures. The range lever will engage the drive, so I’m thinking it may be a malfunction of the electrical interlink which prevents you starting the engine if the tractor is in gear
