Tx Jim
New Member
Ok that clears a lot up. I checked your .089" spec's on the thrust washers is correct. Since your pump uses JD9858 NEEDLE BEARING instead of tapered roller brg similar to the larger pump the shims I posted part #s for are useless to you. Does tech manual give a spec for seating JD 9858 brgs into pump cover or body???
Part Number: R66164
Part Price: 8.75 USD
Description: WASHER, THRUST
Specification
Weight 0.11 LBS 0.05 Kg
Inside Dimension 1.008 IN
Outside Dimension 2.500 IN
Thickness 0.089 IN
24H Type
Service Number
Material 1566
Part Number: R66164
Specification
Thickness 0.089 IN
24H Type
Service Number
Material 1566
