So I replaced the gasket rocker on the left cylinder on my JD320 with the Kawasaki engine. I am concerned with the amount of gunk but will see if if anyone has any advice. The engine runs strong and with the new spark plugs runs even better. Here are some pictures. Was fairly easy to do.
Rocker Removed
I hope it was the Gasket, Rocker that was the reason for all the oil leaking....We'll see
New Part for Rocker Gasket 11061-2182
I bought this machine last spring with 1k hours on it and was told the spark plugs were replaced. I changed the oil as spec'd and decided the plugs should come out.
New Fuel Filter - Next to the old stuff.
Rocker Removed
