I do understand that the gap should become smaller with wear and not larger.
If you're talking about the gap between the finger tips and the throwout bearing face, you have it backwards. I guess that JMclutch adjust link I provided above didn't suit your needs. First,
the clutch pedal moves the throwout bearing carrier
toward the clutch fingers - not the other way around. Then there's your earlier statement citing visible finger wear. That in itself widens the gap. And as the friction discs and pressure plates wear away, the spring tensions are relieved proportionately - also widening the gap. But maybe you're talking about some
other gap (??)
Anyway, adjusting the clutchpack really boils down to preloading the springs again (taking out the slack caused by wear or maladjustment). Doing so necessarily moves the fingers
toward the throwout bearing face, once again narrowing the gap in the process. In fact it's not unusual to have to compensate with the external linkage, and move the TOB farther back (away from the fingers). Unfortunately, working through the windows is a
best guess procedure (relative to actually achieving specified stack height).
The PTO clutch should be adjusted first (1.2mm gap I believe), then the drive clutch (fingers) if necessary. It's important to make sure all three fingers are equidistant from the TOB face (+/- 0.1mm). When you're done working through the inspection windows, then finish up with the final linkage (2.5mm finger gap +/- 0.5mm) and stop bolt adjustments. The stop bolt adjustment isn't described in the book. But unscrew it to the point where the PTO grinds when you try to engage it with the lever. Then tighten the bolt to the point where the grinding quits.
//greg//
