erj
As I asked in post 5 - do you have a multimeter?
You need one to check out those wires and determine where they go.
The first thing that I would do is to use the Ohmmeter and check for continuity between the heavy red wire at the switch and the wire that feeds the Horn Relay fuse. If so, that is the wire that feeds power to multiple fuses in the fusebox. As shown in the information from RonMar and myself, that wire should go on switch terminal #2 (IF the terminals on your new switch operate EXACTLY as the terminals on the original Jinma switch). This would mean that when the new switch is turned right to the first position (on) there is continuity between terminals 1 and 2 on the back of the switch.
