Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,326
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
That is the battery box I have on my 2003 Jinma 254.
Chris
Chris
The LE style battery box mounts low below the radiator, you may want to take a look at it,it will bolt on you will still have to make a few modifications depending on your hood,here is a pic. I'm currently out but have more due in about 2-3 weeks
Tommy
Affordable Tractor Sales
" Your Jinma parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Assuming the correct thermostat is installed, 80C is the normal operating temperature - under load. But when you actually apply a normal load, the temp rises. That suggests the thermostat is either not opening, or is of the wrong temperature range. You'll find it located under the engine side of the upper radiator hose.... I could keep the temp around 80C+. As soon as I ran at more RPM's or load on the tractor the temp started creeping up past 90C.
