Tim_in_IA
Platinum Member
- Joined
- Feb 14, 2005
- Messages
- 830
- Location
- Eastern Iowa
- Tractor
- Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
I have a Jinma 6" PTO wood chipper. The joint that between the feed roller and the drive shaft is rounded on both ends. I see that they have upgraded the driveshaft from the style I have and that is available at circle tractors at least but I'm not seeing the roller anywhere. Any ideas on where to get these or if there is a tractor supplier in this forum could you let me know? I sent Tommy at Affordable Tractors an email based on old posts here but no reply so either Tommy isn't there anymore or Affordable Tractors is gone also? Was hoping this would not be as expensive as it appears it is going to be. I do have a welder but I'm less than a novice.
Thank you
Thank you
