Nuno
Bronze Member
Just found this picture, this is the setup I am going for, though now I'm realising that the pump that came with most LW6s are E10,
will this mean that you now understand what i try to explain in my posting before?
If all else fails, them I'm going to plumb the backhoe into the tractors hydraulics, what do you all reckon about that? good or bad idea?
First off, I apologize the angle of the pump that you showed in post 20 led me (and I think others) to believe that you had the correct pump for mounting to the PTO Auxiliary shaft which is located above the PTO multi-splined shaft.Quote:
Originally Posted by erj
Does this mean that the pump that you showed back in post 20 does not simply bolt onto the spot where you removed the plate?
RonJ
Correct Ron, it's a bigger bracket that also uses 4 bolts to with the 6 splined lower PTO shaft as centre.
