JohnS
Platinum Member
Owners of Jinma 200 series with ZL20 FELs, please take note of this. This picture was recently sent to me from an owner. Needless to say, with only 100 hrs on tractor, he is very upset over this. /forums/images/graemlins/frown.gif While this might be contributed by other things, such as a bad casting, it should at least make some aware that these tractors are not indestructable.
Owners should consider making a rear axle support. An example is: this article But recommend welding to FEL support tubes. Three pt backhoe users, should also consider the stress is going through the transmission/bell housing as well. The frame mount helps distribute the stress.
Also, consider how some adjust the pressure relief valve, without any gauges. Most of the time things are OK, but "bad" things can happen, as well /forums/images/graemlins/frown.gif Not saying that had anything to do with this particular incident.
PS: If this info has not made it to CTOA, please post it there as well. I will post similar at NYCTO.
