sunnyside360
Veteran Member
- Joined
- Aug 8, 2006
- Messages
- 1,565
- Location
- Central PA
- Tractor
- JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Just finished reading this thread and I'd put my money here with Jenkins. I had the identical same experience on my 3720 cab tractor A/C and it turned out to be semi plugged condenser coil just behind the front screen. Thought sure it had be low refrigerant but gauges said otherwise. The condenser didn't look all that dirty but compressed air blew out tons of crud. The A/C then worked like new again. I've also used water to clean radiator and condenser. Amazing how much stuff comes out of there sometimes. If cleaning doesn't fix it I'd turn it over to the dealer for warranty fix. If you called JD service and they found a dirty condenser coil they would likely charge you for the service.................. I would start by cleaning the filters, radiator and condenser coil. If this doesn't solve his problems then at least it will be clean when he takes it to the dealer. Since the OP isn't an hvac technician and the tractor is a 2012 model let the dealer fix it. As you know most people start by adding refrigerant instead of properly trouble shooting the system, I have always disliked coming behind these people to do the actual repairs.
