68BULLITT
Well here goes my first post on here. I bought a JD 4400 HST back in July, no problems runs fine no smoke etc. Here's my issue. If I overload the FEL and stall the machine is usually when this happens but it exhibited this without that happening on friday. I was hauling firewood up to the house and left the loader level with the top step. I got done loading, went to start the tractor and it wouldn't start. I forgot what I did but then I got it to start. When it started, she revved all the way up to 3k. When I shut the machine every time I always drop the rps as low as she'll go. Usually when this happens I'll shut her down engage the park brake, start it up and it's fine. But this time no matter what she revved up to 3k on startup (tried roughly 3x) and I had the hand throttle all the way back. The machine would not change it's revs regardless of where I put the hand throttle. I started it up tonight and still doing the same thing. Is this a common problem, what should I check for. Thank you all in advance
Lou
Lou
