jenkinsph
Super Star Member
I use an L130 to mow the lawn in town which is about two acres total and find it does a good job. I would consider moving up to a 300 series next time and recently looked at the 300R rear bagger with rear discharge deck. It has smooth sides on the deck so you can trim from either side and a built in blower to pack the clippings in the hopper. I particularly liked the short path with large throat between the deck and bagger and find this to be a better design than the bagger on my present L130.
I think it is best to get a lawn in good shape with a larger tractor and implements to get it smooth and flat ( do the prep work needed) then mow with a lighter weight riding mower. I have used my tractors and backhoe to reclaim some rough properties, eliminating some old ditches, burying stumps and hauling off debris, plane the ground, till and plant the lawn. Now it is smooth enough to use the light weight rider.
Just my opinion but I think it saves alot of time to get the yard/lawn in good shape initially where it is easy to mow with just about any mowing machine. Having a rough lawn to work with every week takes alot of fun out of it and this extra time could be better spent each week.
All of this said a 100 series mower will hold up a lot better if you are not constantly beating the crap out of it. It won't pull steep grades as well as the more expensive X300 and up models will and won't last as long either. But overall it does a satisfactory job, mine is 5 years old this year with 260 hours on it, hopefully it will hold up a few more years until I upgrade to something better.
