jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,008
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
chabat124 said:I have a grader/scraper blade, will that be an adequate substitute for a box blade? I have not used the grader blade much... It just came with my tractor from the guy I bought it from.
A grader/scraper blade is only a good tool for doing final leveling or cutting ditches. It is not a good choice for moving materials. The boxblade has sides that keep material from spilling out. You can move around 1/3 yd with a 5' boxblade by dragging the materials on the ground. What you need is to build a dragging path along which you move loads from one area to another. It's a lot like using a dozer in that you build a channel and then drag dirt through that channel each pass.
Using a dirt scoop, you can achieve much higher speed from place-to-place. Because you don't have to worry about dropping the materials over slightly rough terrain, you can haul a lot of material at higher speed with less preparation of your path.
My neighbor built a 50' x 70' pad for his barn with a dirtscoop. He hauled sand from a creek bottom almost 1000' away and made 100s of trips through the woods. I built a 35' x 40' pad for a portable building by a combination of hauling with a dirtscoop and dragging with a boxblade. After building the dragging path that was smooth, I was able to use the boxblade to move more material with each pass than with the scoop. My drag was about 200' long. My tractor was a Ford Jubilee. I'm attaching a picture of the tractor sitting on the finished pad. You can't see how big the pad is, only how high it is on the low end of the slope. I'd say there are at least 25 yd of material in this pad and I did it mostly over one weekend.
My bottom-line point is that a boxblade and dirtscoop are tools that have been used very successfully to do what you describe. The grader blade will come in handy for finish work, but it is not a great materials moving tool. Building your own untested scoop is risky and may end with unsatisfactory results. I'd rent a small tractor with a FEL before I'd attempt to build my own.
