Adirondaquer
- Joined
- May 2, 2009
- Messages
- 20
- Tractor
- Ford 1600
Nice looking tractor. In one of your pics it looks like the tractor rear wheels are off the ground and the stabilizer cylinders are fully extended. The recommended way to set up is to lower the stabilizers only far enough to transfer the weight of the rig from the rear wheels to the stabilizers. That will afford you the maximum digging depth while maintaining maximum stability. Similarly place the loader bucket flat on the ground and apply enough down pressure to transfer the weight of the rig to the bucket. Now you have the longest and widest (and safest) operating platform. Enjoy the rig!
Opti, Thanks for the tips. I appreciate it.
I have a question for you. When I was digging, my stabilizer feet (which are flat steel) was allowing my entire rig slide forward sometimes when trying to dig and scoop into that heavy clay soil. Sort of like it was pulling me to the ditch.
Because of this I tried turning my FEL bucket all the way down so that the edge of the bucket would angle in and dig into the ground a little to prevent me from moving as easily.
What I am wondering is if there is a better method or if the one you described would possibly work better in this instance.
Or should I weld (or buy) something to attach to the stabilizer feet to help stop me from sliding forward as I dig with the BH.
The tires are loaded with fluid but perhaps I may need to attach the rear wheel weights as well. (I thought my large gut would have been enough ballast...)
Are the feet on your stabilizers flat and smooth or do they have some sort of ridges/angle iron or something to help stop it from skidding on the wet grass/dirt?
Thanks.
