...In fact it was funny because the original owner told me it only had "low" and "high" as options for the PTO, yet I found it had 4 location holes for the speed selector. I made my first pass with the PTO set in the 1st selection, and it was running really slow and making a mess so I put it in the highest speed. I rode it around all day and it did an amazing job, but the tractor began to overheat. That's why you'll see in my post that I did some research and have since decided on running it in the second speed of the PTO. The engine has no tach so I have no idea how to judge the speed of the PTO. I do have access to a digital RPM gun that I can stick a piece of reflective tape onto the PTO shaft and it would tell me exactly how fast it was spinning, but I'm lazy.
Owners manual says I was running around 1,200 rpm the first day and that 1st on the PTO is 517. My understanding that 540 is the ideal speed. 2nd is about 760. However the manual does confuse me a bit. It has different speeds if an adapter is used. My tractor does not have the dreaded small PTO and CCW rotation, it has a regular size shaft and turns CW. For me it makes me wonder what the speed actually is. Do I have an aftermarket or OEM reverser? I need to double check the tag but I believe my S370 is a 77 model.
Any advice on the PTO speed would be appreciated.
First. let me say it is my nature to come across as a little overbearing. so please forgive me as I'm not trying to be a jerk.
On the range selector that was probably just a misunderstanding. I believe your transmission range selector has a high and low setting, obviously your pto has 4 speeds.
If you were in fact only running at 1200 RPM no wonder you made a mess in pto speed 1 and overheating. I'm fairly sure you were going a faster than that as idle speed is only 900-1000 rpm. I'm not sure on your tractor, but on my D2000 engine PTO rpm is 2450. I think the S370 is rated at an engine rpm of 2700, but your owners manual should say for sure.
As a reference these are my PTO speeds @ 2450 rpm engine speed:
1 - 540 rpm
2 - 753 rpm
3 - 998 rpm
4 - 1284 rpm
To get 540 rpm on mine in pto 2 I run an engine rpm of 1700. I don't use that very often, only if things are really dry and fairly thin (like the past 2 summers). Those are numbers I came up with a few years ago using my digital non contact tachometer. I got mine from Harbor Freight a few years ago, think they are still around $40, and very handy to have. For a point of reference my MF 230 diesel makes pto speed 540 at an engine RPM of 1600, so it's not a bad idea to check and see just what your tractor actually needs for engine rpm versus pto rpm.
On your tach problem go ahead and check it out, it may be something as simple as one end of the cable is unhooked. If it does require parts there are suppliers out there who can fix you up. I do strongly urge you to repair your tachometer as it is a very necessary instrument in using your tractor correctly.
In your earlier post you I believe you said you're mowing 30 acres with a 4 foot brush hog. Wow. Even though it's tempting, don't use too high of a ground speed when you're mowing as you'll just break things on your tractor (like anti sway chains, lol). By the way, nice job on the anti sway chains you built, those oughta last you forever.
Anyway, nice little tractor you've got there, enjoy using it. If there's anything else I can help you with just ask and either I or someone a lot smarter than I am will try to help.
Ken
