I've explained this so many times that I'm sure most people are going, "Oh, no. Here he goes... again."Scrounger said:I was at the local Kubota dealer and the resident 'old guy' behind the parts counter was telling me that he runs Kerosene all winter long in his tractors to prevent gelling. I thought K1 kerosene was similar to diesel but not the same.
Is it save to run? Its not cheaper around here when compared to off-road diesel, BUT off-road diesel in the Lehigh Valley of PA can't be had unless you buy 200 gallon at a time. Way more than I need.
I would think that just added an additive was the better way to go.
Kerosene, Jet-A, and #1 diesel fuel are similar enough that most (notice I did not say all) refineries can create a single product that meets the specifications of all three. That being said, only if you buy the #1 diesel are you getting a product that they will stand behind for use in diesel engines. Similarly, only the product sold as Jet-A will be certified for use in turbine engines. The least demanding spec is that of kerosene and because there isn't a lot at stake in a kerosene heater, you can run just about anything in it and it is not worth the trouble for most refineries to dedicate production facilities and storage space to kerosene. That's why MOST of the time the kerosene you buy is perfectly fine to run in a diesel--because it was made to be sold as any of three different products, two of which have more demanding specs than kerosene.
If you can find #1 diesel, use that, mixed 50/50 with #2 or straight if you live at the poles. It has to meet all the same specs as #2 diesel. The kerosene you can buy PROBABLY meets those specs, but unless you know, why risk it? Plus, from what I've seen, they think kerosene is liquid gold now.
