First I must say I have not figured out how to change my profile. I have a kioti dk40se with around 60 hours. This is a shuttle shift with a loader. This tractor is stored in a insulated building with cement floor. I have not started it for about three weeks. I went to start it and only get a loud click from the start stop solenoid. I switched the start and stop relays on the fire wall, pulled the ground cable off both ends and cleaned well (it was not dirty). Battery is new with 12.6 vdc.I then pulled the start stop (ss) solenoid out while holding in my hand I cycled the ignition key. The solenoid worked as I think it should. key on plunger out. key off plunger in. There is no safety seat switch on this tractor. The pto is off and the green natural light is on. After going through these steps I tried to jump at the starter.With the key in the on position. When I go from the red positive from the battery to the small red wire all I get is a spark. When I go from the battery positive wire to the other black wire the Bendix spins but the starter does not engage the tractor will not turn over. I have read through hundreds of post and have not found the answer I need. I have a shop manual ordered it should be here early next week. I purchased some more of the relays that are mounted on the firewall. I have not installed them as of yet. Any suggestions appreciated. Thanks in advance Robby
