Kioti K9 2400 CVT belt squeal (similar to Mechron)
   / Kioti K9 2400 CVT belt squeal (similar to Mechron) #11
That machine should have a wet clutch so the cvt belt is under compression all the time and is not a clutch. You may have some contamination on that belt or the clutch is out of adjustment. I'd ask your dealer.
   / Kioti K9 2400 CVT belt squeal (similar to Mechron) #12
I have seen new CVT vehicles burn the belt a bit that puts rubber on the drive clutch. It may wear off with time or harder use. A new machine will have a wide new belt that fits tight between the sheaves. Sometimes a new machine will have a owner that sits alot idling and that is what will burn the rubber to the clutch. As the belt wears there is sufficient clearance for the belt. To stop the squeal, you may have to clean the clutch.
Kioti K9 2400 Manual (Page 131 of 179) | ManualsLib
