Kioti KB2465 Backhoe Stablizers leak down sag problem
/ Kioti KB2465 Backhoe Stablizers leak down sag problem #1
appleo
Upstate, NY
Kioti CK30
Hello....I currently have a KB2465 Backhoe mounted on a Kioti CK30 gear, purchased second hand with 250 hours. Backhoe has seen little use. Prior owner used FEL mostly
Backhoe seems to work strong with the nuisance the hydraulic stabilizer arms appear to sag while operating the boom ... requiring frequent arms extension adjustment with the toggle lever
1. Fluids are full
2, Both cylinders affected sag
3. Two backhoe feed hoses color coded
4. FEL works strong and holds
5. Bypass valve under drivers fender opened the entire way
6. Fluid clear
7. Boom and scoop appear strong
Any ideas>?
Is there a hydraulic schematic available for the KB2465 Backhoe?
All and any ideas appreciated
Thanks! APPLEO
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A59228)
2024 AGT LRT23...
2005 Komatsu HM-400 (A60462)
2005 Komatsu...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A60430)
2019 CUSHMAN...
