justman777
Platinum Member
I installed a Kioti OEM third-function kit almost a year ago when I bought my tractor. Intent was to get a grapple, but life happened and had to wait. I finally got a grapple, and had the opportunity to try it out the other day on moving some brush piles into the fire. No...not the best place to learn how to use it, but you do what you gotta do. Anyway, I realized very quickly that opening/closing the grapple did a few things. First, if you were moving, it slowed the tractor down a bit. Second, I lost the curl/dump function of the loader....which is kinda important when you want to open the grapple and dump stuff at the same time, especially if you're dumping in a fire.
Does everyone else have a similar experience with their Kioti brand third-function? I triple checked the installation instructions, and I have everything connected correctly. If it were a third function, shouldn't I be able to use the dump/curl or full loader function AND open and close the grapple at the same time?
Thanks!
Thanks!
