Stimw
Elite Member
I have 2 Kohler Courage engines, a 25 hp with 170 hours and a 22 hp with 950 hours.
Both are VERY hard to start and appear that the compression release has quit working. I have checked valve adjustment and it is correct.
Both engines run great, ONCE STARTED!
Searching the net it appears this is a common problem with these engines. One only had 19 hours on it when the problem started.
I just got the 22 hp on a Cub Cadet RZT mower. I figured I had two options-
Take the engine off, remove the crankcase cover and repair/replace the camshafts so the release will work. (cams are expensive)
Or add another battery and rig it up to start on 24 volts.
Which is what I did. That cost me $25. for a new battery, $10. for a new solenoid, and some wire and connectors.
I will just have to live with the 25 hp because the tractor is like new.
I have worked on HUNDREDS of Honda Engines (I'm a Honda Engine Dealer) and only found ONE with a problem with the compression release. (spring broke)
Why didn't Kohler correct the problem many, many engines ago???
