kubota b1700 cant get transmission strainer back into tracter
   / kubota b1700 cant get transmission strainer back into tracter #1
edsavage
i removed my transmission strainer cleaned it but it will not screw back in. there must be trick to reseat it before it will screw back in?
   / kubota b1700 cant get transmission strainer back into tracter #2
Could there be some junk stuck in the threads in the frame? May just be a tight fit and need to be aligned straight in before it starts.
   / kubota b1700 cant get transmission strainer back into tracter #3
I tend to put something like that in place, then turn it counterclockwise (as if trying to unscrew it) until I feel the threads drop and then screw it in clockwise.
Yes I tried this I cleaned out the inside threads but still no luck I'll keep working with it
Yes I tried to turn it counterclockwise but it still doesn't connect with the threads I think it needs to be pushed in to connect I'll keep working with it
