aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 18,078
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
The video makes my point. For the first minute of the video the guy has is blade raised and pushes the top of the pile he is not stacking snow he is pushing snow. At the one minute mark he is trying to stack snow and seem to be struggling with it. The tractor is not able to carry the snow that is on the blade at ground level and push it up into the pile. The weight of the snow stalls the loader and he is forced to raise the loader arms losing the snow he had on the blade. As he raises it he is then able to move forward.
I don't know what kind of snow conditions the original poster has but I know the snow conditions we get here this setup does not work as effectively as a blade mounted the way radioman has his mounted. If you look at radioman's picture you can clearly see how he was able to carry the snow up to the top of the pile in one fluid motion. Simple physics will tell you that the further out your blade is and the more weight you have on the loader arms the less you will be able to lift.
Its a function of the angle of the plow. When radiomans plow is going up into the pile, the A frame is angled up (the plow is higher than the pivot point), so his plow goes up. When the guy is pushing into the pile with the bxpanded plow, the A frame is flat or angled down so it is trying to push the whole pile and it runs out of traction.
Aaron Z
