JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,724
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
Well the 3990 came in 2 days ago, but finally got to use it today. Sure gald I got the 39 over the 2690. The 39HP climbed my hills and had to ease up on the peddle because its steep. If I had the 26 I would be ticked off right now, but the 39 did great. The grass and weeds were 2.5 feet and it went right through it, but did need to keep it a bit slower because it was so high.
It's best to always believe what one has is the best one. I'll compare hills in steepness and any day and tall grass and then see if you speak of what you know not. Not having tried a 26 HP your uninformed and making declarations. I've owned the 26 and a couple of 30s and never been HP shy if experience counts over speculation. Any way, your happy and that's what counts for yourself.
Did hit some hard spots and it clipped some rocks, roots a time or three, four, five ..... Its set at 4 inches now, think I'll bring it up another inch to see if it will clear those spots next time. Would be great if I could get my backhoe on the hills to fix those spots but no way.
Eventually you'll have the tops of those rocks and roots trimmed down or remember where they are or discover how to clip over the edges of them to where you don't hit them or just leave them alone.:shocked:
When I was on the JD tractor, I went real slow and many times the angle got way to much so I went another direction. This thing climbs like a goat and never did I ever even a hint it was going to flip/tilt. It slid a tad every now and then, but no worries
Sometimes one has to push the diff lock pedal to get a wee bit more grip, even on the mountain climber. There is also the choice between sort of and a bit more all wheel drive/4wd/3wd which I rarely engage to the most traction mode
On the way to the land cruising flat out in high, all good. On the way after 6 hours of cutting, it had a higher pitch squeal, and when it started to climb a hill it got louder. At home checked fluids and all good. Maybe its just does this, but going to call Barlow tomorrow
I some times move up the road and use the high mode but always move it back when mowing,always because It will go faster in low mode than I can stay on it while mowing and it reduces the whine in low and also guarantees full climbing ability. My money is you left it in high mode thus getting the higher amount of whine.
Sounds like your trying out your F and learning as you go. It's a great mowing machine with 4 tires and metal blades made for mowing grass and weeds and maybe a few small trees. Not a track machine but close.
